Does Quartus generate a "Unused Signal" report for modules that it compiles?
Can Quartus generate a "Unused Signal" report for modules that it compiles? if so, how is it turned on and/or viewed?
after running synthesis, should see the .syn.rpt being generated check screenshot attahced.
Or in GUI, go to compilation report -> Synthesis -> Warning Messages
compilation report -> Synthesis -> Partition "root_partition" -> Optimization Results -> Register Statistics -> Register Removed During Synthesis
Check screenshot attached.
Sheng
- ShengN_altera
Can check the .syn.rpt in output_files folder under section Warnings for <module_name> and Registers Removed During Synthesis. Will have reasons like Pin "" is stuck at GND or Lost fanout.
Sheng
- WShep1
Contributor
Hi ShengN,
I was not able to locate the *.syn.rpt file in the output directory or anywhere else in an of the other project directories. Does it have another name or is it located somewhere else?
Thanks for your timely reponse.
WShep1
- ShengN_altera
Any further concern or update?
Sheng
- ShengN_altera
Sheng
- WShep1
Contributor
Thanks for your assitance with this question
