PSriv8
6 years agoDo ROM and/or Lookup Tables introduce an additional delay to the overall circuit?
I want to design a circuit in which a 5-bit input In[4:0] (ranges from 0 to 31) is associated with a corresponding 3-bit output Out[2:0]. I can design this using a 8x3 Encoder in which 5 out of 8 inp...
KhaiChein_Y_Intel
6 years agoHi,
Do you have any updates? Can you see where the 8x3 encoder located in the Chip Planner?
KhaiY
PSriv8
6 years agoHi,
Thank you for replying me. I do not have the whole design yet, I am still writing codes for other modules for my design. Therefore I could not use the chip planner. However, I understood that whether I will be using the LUT as memory or as encoder, both will introduce delay in the circuit. Thank you for all your replies.
Warm Regards
Pallavi Srivastava
