PSriv8
6 years agoDo ROM and/or Lookup Tables introduce an additional delay to the overall circuit?
I want to design a circuit in which a 5-bit input In[4:0] (ranges from 0 to 31) is associated with a corresponding 3-bit output Out[2:0]. I can design this using a 8x3 Encoder in which 5 out of 8 inp...
KhaiChein_Y_Intel
6 years agoHi,
Where do you implement the 8x3 encoder? Is it in the core logic? Are you using any Intel FPGA IP? If it is in the core logic, the 8x3 encoder is using the LUT as well.
KhaiY
