Do ROM and/or Lookup Tables introduce an additional delay to the overall circuit?
I am sorry for the confusion. I meant adding a register to the output of the data -- synchronous. For Asynchronous and synchrnous circuit, both use the LUT. For combinational functions, the registers are bypassed and the output of the look-up table (LUT) drives directly to the outputs of an ALM. The ALM can drive out registered and unregistered versions of the LUT or adder output depending on your design.
KhaiY
- PSriv86 years ago
Thank you for your reply.
I am using an asynchronous design which needs a Request signal to start a process and Acknowledge Signal is sent once the process is complete, unlike synchronous circuits where clock signal(s) exists to coordinate their activities.
Now if I store the 3-bit data in LUT, where LUT is used as memory.. and I send a Request signal to start the process, would it take additional time to access the data from memory? As I mentioned before, I can also use an 8x3 encoder in place of memory to provide the 3-bit output. Do the memory and encoder both take the same amount of time to process the data once the Request signal is available ?
