dster
1 year agoDNI flow failed
I am getting errors related to the DNI flow process when I compile my project. This is the error below: Flow failed: Failed dni::save_checkpoint - The 'sandboxes/GC1-7CCVH84_3948_0/sld/sld_sysco...
- 1 year ago
Have you tried the Clean Project command from the Project menu?
Also, since checkpoints are mentioned, maybe try disabling Fitter snapshots, though it's not clear why that would be causing an issue. That's in the compilation settings in the Settings dialog box.
Do you get any errors with error number codes or do they all look like this?
sstrell
1 year agoAwesome!
