10 years ago
Divided integer number
Can I divide the integer number (for example, 120) to each of the numbers 1 2 0 in different variables?
    --- Quote Start ---
    use your favorite web search engine an enter double dabble as keywords, you'll find plenty of resources there.
    --- Quote End ---
    Problem solved. This is my code. 133 logic elements
    library ieee;
    use ieee.std_logic_1164.all;
    use ieee.numeric_std.all;
    entity converter is
    port( INPUT12bit: in unsigned (11 downto 0):="000000101010";
    digit1_out: buffer integer range 0 to 10;
    digit2_out: buffer integer range 0 to 10;
    digit3_out: buffer integer range 0 to 10;
    digit4_out: buffer integer range 0 to 10;
    clk :in std_logic);
    end entity;
    architecture main of converter is
    begin
    process(clk)
    variable digit1: integer range 0 to 10;
    variable digit2: integer range 0 to 10;
    variable digit3: integer range 0 to 10;
    variable digit4: integer range 0 to 10;
    VARIABLE decount_INPUT12bit :unsigned (11 downto 0);
    variable default_INPUT12bit :unsigned (11 downto 0);
    variable LAST_INPUT12bit :unsigned (11 downto 0);
    variable LAST1_INPUT12bit :unsigned (11 downto 0);
    variable ENABLE: std_logic:='0';
    begin
    if rising_edge(clk) then
    if ENABLE='1' then
    decount_INPUT12bit := decount_INPUT12bit - 1;
    digit1:=digit1 + 1;
    if digit1=10 then
    digit1:=0;
    digit2:=digit2 + 1;
    if digit2=10 then
    digit2:=0;
    digit3:=digit3 + 1;
    if digit3=10 then
    digit3:=0;
    digit4:=digit4 + 1;
    end if;
    end if;
    end if;
    end if;
    if LAST_INPUT12bit/=INPUT12bit then
    ENABLE:='1';
    if INPUT12bit/=LAST1_INPUT12bit then
    decount_INPUT12bit:=INPUT12bit;
    default_INPUT12bit:=INPUT12bit;
    LAST1_INPUT12bit:=INPUT12bit;
    digit1:=0;
    digit2:=0;
    digit3:=0;
    digit4:=0;
    end if;
    end if;
    if decount_INPUT12bit = "000000000000" then
    LAST_INPUT12bit:=default_INPUT12bit;
    ENABLE:='0';
    digit1_out<=digit1;
    digit2_out<=digit2;
    digit3_out<=digit3;
    digit4_out<=digit4;
    end if;
    end if;
    end process;
    end main;
    This might have a small logic footprint, but I can see the performance being rather poor, due to the large cascaded logic chains because of no pipelining.
    --- Quote Start ---
    --- Quote End ---
    Yes I need little logic elements. Slow transfer no harm. This module will be multiplexed for 8 digits - 4digit and 4 digit
    Could you use code tags when posting code in the future?
    This makes it way esier to read.
