10 years agoDivided integer number
Can I divide the integer number (for example, 120) to each of the numbers 1 2 0 in different variables?
10 years ago --- Quote Start --- use your favorite web search engine an enter double dabble as keywords, you'll find plenty of resources there. --- Quote End --- Problem solved. This is my code. 133 logic elements library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity converter is port( INPUT12bit: in unsigned (11 downto 0):="000000101010"; digit1_out: buffer integer range 0 to 10; digit2_out: buffer integer range 0 to 10; digit3_out: buffer integer range 0 to 10; digit4_out: buffer integer range 0 to 10; clk :in std_logic); end entity; architecture main of converter is begin process(clk) variable digit1: integer range 0 to 10; variable digit2: integer range 0 to 10; variable digit3: integer range 0 to 10; variable digit4: integer range 0 to 10; VARIABLE decount_INPUT12bit :unsigned (11 downto 0); variable default_INPUT12bit :unsigned (11 downto 0); variable LAST_INPUT12bit :unsigned (11 downto 0); variable LAST1_INPUT12bit :unsigned (11 downto 0); variable ENABLE: std_logic:='0'; begin if rising_edge(clk) then if ENABLE='1' then decount_INPUT12bit := decount_INPUT12bit - 1; digit1:=digit1 + 1; if digit1=10 then digit1:=0; digit2:=digit2 + 1; if digit2=10 then digit2:=0; digit3:=digit3 + 1; if digit3=10 then digit3:=0; digit4:=digit4 + 1; end if; end if; end if; end if; if LAST_INPUT12bit/=INPUT12bit then ENABLE:='1'; if INPUT12bit/=LAST1_INPUT12bit then decount_INPUT12bit:=INPUT12bit; default_INPUT12bit:=INPUT12bit; LAST1_INPUT12bit:=INPUT12bit; digit1:=0; digit2:=0; digit3:=0; digit4:=0; end if; end if; if decount_INPUT12bit = "000000000000" then LAST_INPUT12bit:=default_INPUT12bit; ENABLE:='0'; digit1_out<=digit1; digit2_out<=digit2; digit3_out<=digit3; digit4_out<=digit4; end if; end if; end process; end main;
