DisplayPort IP not seeing Synthesis option on
Hi Drew,
Good day.
Thank you for your patience.
For DisplayPort IP, the are a number of design example available to choose from, you may refer to below table:
F-tile Displayport IP Design Example User Guide
I have tested with the same settings that you use, and I observe there are some setting that you need to turn on in order to enable the design example.
You may enable/disable the settings as mentioned in above table in order to allow the design example to appear on the "select design" option under the available design example tab in IP Parameter Editor.
Screenshot
Allow me to clarify some items below:
Q1. Did you able to see the design example option appear in IP parameter editor as below?
Screenshot1
Q2. May I know which design example that you intent to use?
Q3. May I know which operating system and, Quartus version you are using?
Looking forward to hear back from you so that we can proceed for next step.
Thank you.
ZH_Intel
- MATRIX78782 years ago
Yes, I can see the Design Example tab appear.
I want to be able to do both RX and TX. I think though that I am trying to generate a single file that does both at the same time. I might have been trying to think of it like a I2C bus that is bidirectional.
I am using Windows 11 V. 23H2 and Quartus 23.4.
Thank you,
Drew
