12 years ago
Difficulties in causing the vga to count from 0 to 799
Hi guys,
can someone help me figure out why this code does not function properly. counter_int_v and counter_int_h is what i want to get counting in modelsim but i am not able to figure out the problem.
Found below is my code:
Library ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.all;
USE ieee.std_logic_arith.all;
entity VHDL_uppgift_8 is
port(
reset_n, CLOCK_50 : in std_logic;
KEY : in std_logic_vector(3 downto 0);
-- to the VGA unit/block
VGA_HS, VGA_VS, VGA_CLK : out std_logic;
VGA_BLANK_N, VGA_SYNC_N : out std_logic;
VGA_B, VGA_G, VGA_R : out std_logic_vector(7 downto 0)
end VHDL_uppgift_8;
architecture VGA_ARCH of VHDL_uppgift_8 is
--Kanske mycket tydligare (robustare) att ha en X och en Y unsigned med range. En record kanske är overkill, men kul att använda (se VHDL boken sidan 81).
--using record type to involve elements with different data types
type HV_type is record
H : INTEGER range 0 to 799;
V : INTEGER range 0 to 524;
end record;
signal counter_int_h : hv_type;
signal counter_int_v : hv_type;
signal clk_25mhz : std_logic := '0';
signal KEY_internal : std_logic_vector(3 downto 0);
signal x : std_logic_vector(8 downto 0):= "101000000"; --X'320'--;
signal y : std_logic_vector(7 downto 0):= "11110000"; --Y'240'--;
begin
VGA_CLK <= clk_25mhz; -- dett var något med att en klocka skall ut till VGA kontrollerns, kolla med DE2 manualen
KEY_internal <= NOT KEY;
-- Process to divide clock by two counter--
process_clock_25mhz: process (clock_50)
begin
if rising_edge(clock_50) then
clk_25mhz <= not clk_25mhz;
end if;
end process;
process_coordinate : process (reset_n, clk_25mhz)
begin
if(reset_n = '0') then
x <= "101000000"; --Starting value on X
y <= "11110000"; --Starting value on Y
else
if rising_edge(clk_25mhz) then
if KEY_internal (0) = '1' then
x <= x + 1;
end if;
if KEY_internal(1) = '1' then
x <= x - 1;
end if;
if KEY_internal(2) = '1' then
y <= y + 1;
end if;
if KEY_internal(3) = '1' then
y <= y - 1;
end if;
end if;
end if;
end process;
-- Process to generate Hsync an Vsync
process_sync_screen : process (clk_25mhz)
begin
if reset_n = '0' then -- The next day the reset has been changed to synchronous reset
counter_int_h <= (others =>'0') ;
counter_int_v <= (others =>'0');
-- Starting values for the outputs
VGA_HS <= '1';
VGA_VS <= '1';
VGA_BLANK_N <= '1'; -- Pedroni says nblank and nsync must be kept at '1' and '0' respectively
VGA_SYNC_N <= '0'; --
VGA_R <=(others =>'0');
VGA_G <=(others =>'0');
VGA_B <=(others =>'0');
else
-- count h up
-- Clock out RGB Pixel Row Data Horizontal Sync--
-- ------------------------------------__________--------
-- 0 639 659 755 799
if counter_int_h >= 799 then
counter_int_h <= (others => '0');
else
counter_int_h <= counter_int_h + 1;
end if;
-- HSync Generation ('0')--
-- 0 659 755
if (counter_int_h <= 755) and (counter_int_h >= 659) then
VGA_HS <= '0';
else
VGA_HS <= '1';
end if;
-- 480 Horizontal Sync (pixel rows) Vertical Sync
-- ---------------------------------------_______----------
-- 0 480 493-494 524
if (counter_int_v >= 524) and (counter_int_h >= 707) then
counter_int_v <= (others => '0');
elsif counter_int_h = 707 then
counter_int_v <= counter_int_v + 1;
end if;
--VSync Generation ('0') --
-- 0 493-494
if (counter_int_v <= 494) and (counter_int_v >= 493) then
VGA_VS <= '0';
else
VGA_VS <= '1';
end if;
-- This is when blank will be low(active)
if counter_int_h <= 639 then
VGA_BLANK_N <= '1';
else
VGA_BLANK_N <= '0';
end if;
-- This is when sync will be low (active)
if counter_int_v <= 479 then
VGA_SYNC_N <= '1';
else
VGA_SYNC_N <= '0';
end if;
if((counter_int_h >= x and counter_int_h <= x+3) and (counter_int_v >= y and counter_int_v <= y+3) )then
-- white color ----------------------------------
VGA_R <= "11111111";
VGA_G <= "11111111";
VGA_B <= "11111111";
else
-- No color -------------------------------------
VGA_R <= "00000000";
VGA_G <= "00000000";
VGA_B <= "00000000";
end if;
end if;
end if;
end process process_sync_screen;
end VGA_ARCH;
    Thanks all for the coorperation, if this works fine with you guys i don't understand why it is messing up with me.
    Did you do any thing to your testbench, probably thats why mine is not working?
    --- Quote Start ---
    --- Quote End ---
    I did not use any testbench code but just injected input stimuli and looked at counting.
    your counter is only under reset_n and as long as this signal is high the counting if free running so how come you get it stopped at 12 or 13. It could be just bad luck.
    Hi to everyone. I am also trying to implement something like that but using schematic. The Point is that i also want to make a 12 bit Counter which consists of 3 4*bit Counters and unfortunately it also does not work correctly. The calculation is the following : 4095-1-752(steps)=3342=110100001110. Here is the circuit i have but when i simulate it the results are at least tragic....
