11 years ago --- Quote Start --- Thanks all for the coorperation, if this works fine with you guys i don't understand why it is messing up with me. Did you do any thing to your testbench, probably thats why mine is not working? --- Quote End --- I did not use any testbench code but just injected input stimuli and looked at counting. your counter is only under reset_n and as long as this signal is high the counting if free running so how come you get it stopped at 12 or 13. It could be just bad luck.
