15 years agoDifferential pins and clock constraints
I had a question about writing timing constraints for differential pins. I am constraing an interface between a Cyclone II and an AD9726 fast dac. The FPGA provides 16 differential data outputs along with a differential data clock to the DAC.
My constraints as of now are (CLK_100MHZ is clock input to FPGA): create_generated_clock -name FDAC1_DCKIN -source [get_ports {CLK_100MHZ}] [get_ports {FDAC1_DCKIN}] set_output_delay -clock FDAC1_DCKIN -min 0.000 [get_ports {FDAC1_D [*]*}] set_output_delay -clock FDAC1_DCKIN -max 0.000 [get_ports {FDAC1_D [*]*}] The first problem I had was timequest reporting that all the complement data pins, FDAC1_D [*](n), were not constrained. I fixed this by adding the extra '*' to FDAC1_D [*]. But how do I constrain the differential clock FDAC1_DCKIN? I tried creating a generated clock that applied to both FDAC1_DCKIN and FDAC1_DCKIN(n) but timequest complained no paths existed. Anyone have experience with this?
