13 years agoDifferent PLLs' output phase controlling issue
Hello everyone:
I have a question about PLL need your help. System description: There are 11 veneers, and there are two same FPGAs on each board. The input clocks for each FPGA are from same source through clock buffer chip. Requirment: Can PLLs inside each FPGA output a clock with same phase or with a known phase? (Disregard the clock buffer chip's phase error and the hardware trace routing differance). According my memory, the PLL output's phase is same as the input clock when the PLL works at normal mode, am i right?
