16 years agoDifferent compiling results ModelSim <-> Quartus 9.0
I have a VHDL Design containing a case statement. If I compile this design with QuartusII 9.0 I get no error; compiling this design in ModelSim Altera Starter Edition I get some errors like "Array type case expression must be of a locally static subtype" and "Case choice must be a locally static expression". I Think the reason is that I use a "generic expression" in the case-statement. Why did Quartus compile that without errors and ModelSim do not? The synthesized Design will work, but I will do the simulation as well. Any ideas to solve the problem? I attached the VHDL code... Thanks for help!
