9 years agoDifference float calculation on FPGA and CPU
Hi, I use float point calculation in convolution neural network (opencl). Result of calcultaion on FPGA and CPU is similar, but in low byte I get some difference. How can I fix this problem ? ...
9 years agoAs long as the floating point operations are carried out in the same order as the CPU code, the output will be exactly the same on the FPGA (a + b + c is not the same as a + c + b or any other permutation of adding these three numbers). Note that parallelizing (including using SIMD) a floating point reduction in an NDRange kernel, or optimizing such operation in a single work-item kernel using a shift register (as outlined in Alrtera's documents) will result in a slightly different output compared to sequential execution on a CPU.
