11 years agoDesign Space Explorer issue
I'm using Quartus II 14.1 64b and DSE II launched from Quartus gui. Running on Centos 7 Linux.
When I try to run DSE (for a seed sweep) from its gui, I get the following error Traceback (most recent call last): File "<string>", line 22, in <module> File "explorer.py", line 1379, in main File "explorer.py", line 1286, in main_impl File "explorer.py", line 346, in run AttributeError: 'Explorer' object has no attribute 'server_url' Design Space Explorer finished Found info that says DSE II wants to use a local server but I'm at a loss as to what I need to do to get the tool to run. DSE II seems to be quite new and documentation is a bit sparse. Any thoughts/help would be appreciated.1 Reply
- RMowb
Did you have any luck with this -- I have same issue and stuck as to where to start...
