15 years ago
Design Space Explorer: how to ignore hold time slack
From Quartus manual about Design Space Explorer (DSE):
"In an exploration for best performance, DSE works on reducing the worst magnitude
slack, regardless of whether it is a hold slack or setup slack."
But I would like to instruct DSE to reduce setup time slack rather than hold time slack.
Is it possible to do this by ignore hold time constrain in SDC file?
Or other method?
    --- Quote Start ---
    Or other method?
    --- Quote End ---
    unfortunately you have to solve both in order to make your design running. I would first
    look to the holdtime violations, because they are often caused by design issue like gated gated etc. clock. After solving the holdtime you can run the DSE for setup optimizations.
    Another solutions is to cut all paths with holdtime violations, but I would not recommend
    it. I'm pretty sure that your design will not work properly.
    Kind regards
    GPK
    I recently had this problem with a project. I did the following:
    quartus_sh --set -rev toprev TIMEQUEST_MULTICORNER_ANALYSIS=OFF top
    <insert command you run dse with here>
    cd dse
    quartus_sh --restore -output best_restored best.qar
    cd best_restored
    quartus_sh --set -rev __dse_temp_rev TIMEQUEST_MULTICORNER_ANALYSIS=ON top
    quartus_sta mpsc -c __dse_temp_rev
    In the example, top is the name of the proejct .qpf and toprev is the name of the revision(.qsf). In most designs these are the same. It first modifies the project to analyze the slow corner only. By not analyzing the fast corner, you are essentially ignoring hold violations(hopefully). It runs DSE, then unqars the best one, turns multicorner timing analysis back on, and then runs TimeQuest on the back end, so the project will contain timing on all three corners, but DSE's selection for Best was only based on the slow corner.
