14 years agoI am not saying don't worry about existing violations...
I am saying concluding from results is misleading if violations do occur. Your clock uncertainty from .3 to 1.2 is not relaxing but more constraining. I do believe using both edges is problematic but I assume tool will detect timing errors across. However I believe you may pass timing yet sample the data wrongly across edge to edhe transfer. Thus a functional simulation may fail. You may not noticed that unless you use same input pattern.
