SKon1
6 years ago"derive_pll_clocks" doesn't create generated clocks properly
"derive_pll_clocks" doesn't create generated clocks properly Hello, In my Arria V design. I have a PLL with one input and 3 outputs. The input is 125 MHz. The outputs are as follows: 1. Output 0 ...
SKon1
6 years agoAs a side note.
IMO, having the fact that Quartus has this option enabled by default is a bad idea.
