SKon1
6 years ago"derive_pll_clocks" doesn't create generated clocks properly
"derive_pll_clocks" doesn't create generated clocks properly Hello, In my Arria V design. I have a PLL with one input and 3 outputs. The input is 125 MHz. The outputs are as follows: 1. Output 0 ...
KhaiChein_Y_Intel
6 years agoHi,
Can you share the design for investigation? What is the edition (Pro/Standard) and version you are using?
KhaiY
