8 years agodelay a signal by several clk cycles in verilog
Is there anyone knows an easier way to delay a signal by several clk cycles in verilog I was trying to use repeat as below, however, it only works when I run RTL simulation, it will not work when I run gate level simulation. data_out <= repeat (15) @(posedge clk ) data; Thanks!!1 Reply
--- Quote Start --- Hi, Is there anyone knows an easier way to delay a signal by several clk cycles in verilog I was trying to use repeat as below, however, it only works when I run RTL simulation, it will not work when I run gate level simulation. data_out <= repeat (15) @(posedge clk ) data; Thanks!! --- Quote End --- It's called a SHIFT REGISTER. Google: shift register verilog code
