11 years ago
Debounce Verilog ( I have some questions)
hello everyone. i'm new to verilog programming. i have some questions on debouncer. I already get the concept of debouncing. but how do i compute for the length of the register that i would be using.
i would be using this for a pushbutton on DE1. evrytime i press the button, there are still a lot of increments even with this debouncer. i am using 24MHz clock.
here's my code:
module dbc(pbnoisy, clk, pbclean);
input wire pbnoisy, clk;
output reg pbclean;
parameter N=8;
reg [ N - 1 : 0 ] ctr;
always @(posedge clk)
begin
ctr [ N -1 : 0 ] <= {ctr[N-2:0] , pbnoisy};
if ( ctr[N-1:0] == 8'b00000000)
pbclean <= 1;
else
if ( ctr[N-1:0] == 8'b11111111)
pbclean <= 0;
else pbclean <= pbclean;
end
endmodule
please help. thanks
    The filter time must be longer than the bouncing settling time.
    An unfiltered pushbutton is likely to have bouncing spikes extending in the 100us - 1ms range, so you need to sample the level for a few ms.
    With a 24MHz and 8 samples you achieve a filter "low pass" frequency of about 3MHz which is totally ineffective.
    You must use a lower frequency sampling: if you keep the 8 samples, choose a sample rate around 10kHz.
    --- Quote Start ---
    --- Quote End ---
    thanks. but, what do you mean? i change my 24MHz clock? or the number of samples? i tried increasing the number of samples, still i get same results. please help.
    You can keep on using the 24mhz clock and 8 sample. You can simply define a counter and inside the always @(posedge clk) process you place the sampling in a conditional statement. For example:
    counter <= counter + 1;
    if (counter == 1000)
    begin
    <sample here the input>
    counter <= 0;
    end
    --- Quote Start ---
    begin
    counter <= 0;
    end
    --- Quote End ---
    dude please help. i changed my debouncer to this one:
    output reg pbclean;
    parameter N=8;
    reg [ 12 : 0] M;
    initial
    begin
    M <= 0;
    pbclean <= 0;
    end
    begin
    M = M + 1;
    if (M == 3_000_000) pbclean <= 1;
    else pbclean <= 0;
    end
    endmodule
    and on my main code i called it by this:
    wire pb3;
    dbc dbc3( !PB[3], ClOCK_24A, pb3);
    also i used this for incrementing:
    if (pb3)
    begin
    ctr <= ctr + 1;
    end
    however, nothing happens when i press PB[3]. what should be done?
    --- Quote Start ---
    --- Quote End ---
    That's correct!
    According to your code nothing should happen.
    You'd better consider how the input signal 'pbnoisy' is supposed to affect the output... since you don't use it.
    Moreover, I'd reset M when you reach the threshold condition, otherwise you'd have one-shot operation.
