Shehab
2 years agoDE10-Lite VGA Controller Display
this is my design: https://github.com/Shehab-Hesham/FPGA_IP_VGA/tree/main. On an oscilloscope, the vertical sync and horizontal sync are correctly given as output; however, the color channels outpu...
Shehab
2 years agoHello,
Thank you for your reply,
1. I am not using any IP, I designed the controller seen in my GitHub from scratch, do I have to integrate an IP into it? If yes, how?
2. Yes, I have. I am using the DE10-Lite Pin Assignments offered by Intel and I am correctly assigning the pins to the appropriate module outputs.
Kind Regards,
