13 years ago
DE0-Nano-Programming
Helo,
just i wants to glow the leds of DE0-Nano, for that i wrote simple program, but error only coming.Any tutorials for programming?
Quartus II ananlysis and systhesis was unsuccessful.(quartus 10.1 i am using)
Alex.
    Try this:
    -- KEY0 - PIN_J15
    -- LED0 - PIN_A15
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.all;
    ENTITY Test IS
    	PORT
    		KEY0	: IN	STD_LOGIC;
    		LED0	: OUT	STD_LOGIC
    END Test;
    ARCHITECTURE a OF Test IS
    BEGIN
    	LED0 <= KEY0;
    END a;
    There is a 50 MHz incoming clock on the DE-Nano. I suggest dividing this down to 1 MHz with the PLL megafunction, then creating a 3 Hz tick signal from the 1 MHz clock. Then drive all eight LEDS with this 3 Hz heartbeat signal, alternating with the logical not every other LED. In this way, you can really see that the logic in the FPGA is fundamentally working, and all LED's are okay.
    	   LED Outputs
    	LED_OUT(0) <= hb_led;
    	LED_OUT(1) <= not(hb_led);
    	LED_OUT(2) <= hb_led;
    	LED_OUT(3) <= not(hb_led);
    	LED_OUT(4) <= hb_led;
    	LED_OUT(5) <= not(hb_led);
    	LED_OUT(6) <= hb_led;
    	LED_OUT(7) <= not(hb_led);
    Thanks, i copied and paste into my quartus window, but its showing error like
    Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
    Error: Peak virtual memory: 222 megabytes
    Error: Processing ended: Tue Sep 18 10:56:06 2012
    Error: Elapsed time: 00:00:04
    Error: Total CPU time (on all processors): 00:00:02
    Sory for the lack of knowledge.
    Alex.
    You need to look for the actual error message. It should be further up in the log window, and you can't miss it, it will be in red.
