11 years agoDDR3 with Uniphy on Cyclone V
I'm trying to interface a DDR3 memory with UNIPHY with a custom component in QSYS. After successful generation of the HDL files, Analysis and synthesis was done which was successful. The <>_pin_assignments.tcl script was run and errors were seen. I have attached the log file of the errors. Due to this, Place and fitter had hundreds of the following error: Error (174068): Output buffer atom "system_DDR3_Memory:ddr3_memory|system_DDR3_Memory_p0:p0|system_DDR3_Memory_p0_memphy:umemphy|system_DDR3_Memory_p0_new_io_pads:uio_pads|system_DDR3_Memory_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_cyclonev:altdq_dqs2_inst|pad_gen[3].data_out" has port "PARALLELTERMINATIONCONTROL[5]" connected, but does not use calibrated on-chip termination I'm using a Cyclone V SX SoC device with Quartus 14.1 version. Please let me know if I'm missing something. Thanks and Regards, Nitin.
