anhnidnahp
2 years agoDDR3 SDRAM Controller with Uniphy intel FPGA IP 22.1 failed
Hi Intel team, Please see below for the error message when i am generating the DDR3 IP. Info: p0: "mem_if_ddr3_emif_0" instantiated altera_mem_if_ddr3_phy_core "p0" Info: m0: "mem_if_ddr3_emif_0" ...
AdzimZM_Altera
2 years agoHello
Thank you for your feedback.
The installation parts look normal based on the screenshots that you have provided.
The windows build version also should be supported.
There a few things that might be helpful to resolve this based on the use cases.
- There are some interruption that might happen during the installation progress if using VPN.
- Try to disconnect from VPN during the installation progress.
- Set the default version for WSL.
- You may run this command to set the default version: wsl --set-default-version 1
- Running application from NIOS II Command Shell.
- Try to run a command in the NIOS II Command Shell such as make or jtagconfig.exe.
- Link to NIOS II Handbook: https://www.intel.com/content/www/us/en/docs/programmable/683525/21-3/running-make.html
- Try to run the Quartus software in administrator privileges.
Adzim
