MPaso
8 years agoDDR3 burst size
Hello everybody I have a system with CYCLONE V and DDR3 2Gbit memory (16bit data bus and 14 bit address bus). The DDR3 is connected to HMC pins of the FPGA. When i go to the UniPHY memory DDR3 compo...
MPaso
8 years agoThank you for the answer.
Can you or anybody else then further elaborate how are Avalon burst length and DDR3 external memory burst length related.
When i read the datasheet of the DDR3 the BL is 8. Then there is also the issue of address boundary. Since I wrote my own mm master to write/read to and from DDR3 in this case does it mean that i have to only provide an address and burst length to UniPHY and all the correct addressing and data access will be automatically arranged or do i have to make sure that boundary addressing is handled correctly and every 8 access (assuming DDR BL) my mm master must update the address?
Thank you
