16 years agoDDR2 memory design failed
Generated a test case from external memory IP for DDR2 design, When I ran the design in QuartusII, it is giving error message as follows, Can some help me with the case...I looked into the Altera Web but i couldn't find solution.
Error: Cannot place pin mem_clk[0] to location J16 Error: Can't place VREF pin L14 (VREFGROUP_B5_N0) for pin mem_clk[0] of type bi-directional with SSTL-18 Class I I/O standard at location J16 Error: Too many output and bidirectional pins per VCCIO and ground pair in I/O bank 5 when the VREF pin L14 (VREFGROUP_B5_N0) is used on device EP3C10F256C7 -- no more than 9 output/bidirectional pins within 14 consecutive pads are allowed when the voltage reference pins are driving in, but there are potentially 12 pins driving out.
