16 years agoDCFIFO and DMA...
I have a dcfifo in my design (wich is interfacing two different clocks domains...)... I want to copy the FIFO (not in SOPC) content on an SRAM memory using the DMA (from SOPC). Does anyone know how to do it ? I have a look on the an473 (http://www.altera.com/literature/an/an473.pdf) (using DCFIFO for data transfer between Asynchronous Clock Domains). This AN don't explain how to do it with a DMA module. In the DMA docs, I don't find anything about using DMA with a FIFO... Someones suggest me the use of an "Avalon to External Bus Bridge", but this IP Block (available from university program) seems to work as an Handshake Protocol (as mentioned in the AN473) So, is it possible to use a DMA with the Avalon to External Bus Bridge ? How can I interface a FIFO with a memory block (SRAM) using a DMA ? Many thanks.
