Holden
2 years agoCyclone10LP: Unable to assign pins documented as DIFFIO
Hi, I am working on updating a design for a 10CL120YF484I7G device. This design has been fielded and as such has been built successfully in the past (last build was 2/28/2022). However, opening the ...
- 2 years agoHi,
most likely explanation is that you have defined migration compatibility in your project. So it's not only considering 10CL120 but also other devices pinout.
Holden
2 years agoThank you. That was apparently it. I removed all migration devices and was able to build as expected.
