11 years agoCyclone V DSP blocks
I am using a Cyclone V board with a device with 25 DSP Blocks. Compiling the design I have a fitter error message stating design need 37 DSP blocks while just 25 are available. I can sinthesize the design without using any DSP blocks and using only logic. How can I set Quartus II to use the 25 DSP blocks available and then sinthesize the remaining multipliers using logic? thanks and best regards. Stefano1 Reply
I've just tried to reproduce your error with a small project in a Cyclone V E A2 device, instantiating 37 multipliers. My results don't tie up with yours. During analysis & synthesis it identifies the 'need' for 37 DSP Blocks. However, once it's been through the fitter this reduces to 25 (100%) and implements the balance in logic (ALMs).
Check these two settings:- Auto DSP Block Replacement - ON
- DSP Block Balancing - Auto
