11 years agoCyclone V DSP blocks
Hi, I am using a Cyclone V board with a device with 25 DSP Blocks. Compiling the design I have a fitter error message stating design need 37 DSP blocks while just 25 are available. I can sint...
11 years agoI've just tried to reproduce your error with a small project in a Cyclone V E A2 device, instantiating 37 multipliers. My results don't tie up with yours. During analysis & synthesis it identifies the 'need' for 37 DSP Blocks. However, once it's been through the fitter this reduces to 25 (100%) and implements the balance in logic (ALMs).
Check these two settings:- Auto DSP Block Replacement - ON
- DSP Block Balancing - Auto
