YuanLi_S_Intel
3 years agoCan you check if the device part number is selected correctly in the quartus design? Also, the device part number and flash part number EPCQ64A is correct during JIC generation.
AWann1
3 years agoYes, I confirmed the FPGA Device is correctly selected, EPC3LS70, and the memory is set to EPCQ64A.
I also checked the box in the convert programming file window that says "Disable EPCS ID check"
