Cyclone 10GX design Simulation Error
I have generated simulation library files from Quartus Prime Pro 2020.4 Tool. In my project I have remote update IP.
When i try to run netlist simulation with Modelsim 2020.4 and QuestaSim 2021.4, I am getting below error
Please help me on this.
- TingJiangT_Intel
Contributor
Are you using custom script for simulation? If so you may use the script generated by Quartus as reference.
Seems some instances don't exist in your design but didn't show in the error message. Need more information about what you do and what your project contains.
- TingJiangT_Intel
Contributor
- Sumanth
I am using the script generated by Quartus as reference.
I have resolved the issue now.
The issue is resolved after removing the below files during simulation library generation.eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/cyclone10gx_atoms_ncrypt.v" -work cyclone10gx
eval vlog $USER_DEFINED_VERILOG_COMPILE_OPTIONS $USER_DEFINED_COMPILE_OPTIONS "$QUARTUS_INSTALL_DIR/eda/sim_lib/mentor/cyclone10gx_atoms_ncrypt.v" -work cyclone10gx_ver
Thanks for the support.
