Creation of jic file for qspi with signed factory and user rbf
We are adding authentication to a design that uses a jic file to program a QSPI with two pages containing factory and user images. We use Programming File Generator to create the jic. The original (before authentication) jic file used sof input files for both factory and user. I can successfully replace the user file with a signed rbf, but if I change the factory image from sof to rbf I get a missing boot info error.
If I only have one (i.e. factory) page, then the signed rbf works. It's only when I have multiple pages/images that the missing boot info error occurs. What is the solution to create signed factory and user images? i.e. how do I fill in the missing boot info?
- billmaxsrc
The solution is detailed in combination of Agilex 7 Device Security User Guide (sec 5.5) and Agilex7 Configuration User Guide (sec 5.5.1.2)
- FakhrulA_altera
Thanks for the clarification. I am glad that the you have found the solution. I now transition this thread to community support. This will be a good reference and really help the communities here if they facing the similar issue in future. Really appreciate you effort.
