16 years ago
creating .pof file
Hi all,
I am using a CycloneIII FPGA. When I compile my design, only a .sof file is created but not a .pof file. What should I configure in order to create a .pof file (for Active Serial Programming)?
Dvido
    The strange behavior is that it didn't work and then suddenly it started working.
    gpio14 is coming from another FPGA with a very low frequency, there shouldn't be any timing issue since I don't use the clock for that process.
    I ran it now for a few times and it works fine.
    --- Quote Start ---
    --- Quote End ---
    but you use the gpio14 as a clock ! (gpio14'event and gpio14 = '1'). If you use signals generated in this block in a block with a different clock
    your design will not work stable. BTW did you connect yor reset signal ?
    Kind regards
    GPK
    I use the start_handshake_fsm signal only as a flag for another process. Though the other process uses another clock, it doesn't matter. As I said now its working.
    I did connect the reset signal.
    Might be that the FPGA was "stuck" and when I switched the power off for the night it fixed it?
    --- Quote Start ---
    --- Quote End ---
    how did you synchronize your handshake signal in the other clock domain, in order to prevent metastability ? That could be the reason why your design is stuck .
    Kind regards
    GPK
    I put an if condition on the other process:
    if (rising_edge(clk) and start_handshake_fsm = '1') then....
    is that a problem?
    --- Quote Start ---
    is that a problem?
    --- Quote End ---
    this could be a problem. I assume that "clk" is much faster then the gpio signal.
    In this case you should latch the handshake signal with two registers in a row clocked by "clk". For more info's look:
    http://www.fpga4fun.com/crossclockdomain1.html
    Kind regards
    GPK
