OHarb1
6 years agoCrash when programming .sof file
I saw this crash while programming a .sof file on Ubuntu: Has anyone else run into this? *** Fatal Error: Segment Violation at 0x22f700000076 Module: quartus_pgm Stack Trace: 0xf8ea: rml::i...
JohnT_Altera
6 years agoHi,
Is it possible to change your script to utilize quartus_pgm rather than nios2-configure-sof? you can use the command "quartus_pgm -c 1 top.sof". Please refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/TclScriptRefMnl.pdf for more information.
OHarb1
6 years agoI'll see if I can do that. A good suggestion. Though... if you look at the stack trace, you'll find that the crash is in the quartus_pgm process, so nios2-configure-sof must be launching quartus_pgm.
I'll also upgrade to the latest quartus_pgm.
