OHarb1
6 years agoCrash when programming .sof file
I saw this crash while programming a .sof file on Ubuntu: Has anyone else run into this? *** Fatal Error: Segment Violation at 0x22f700000076 Module: quartus_pgm Stack Trace: 0xf8ea: rml::i...
JohnT_Altera
6 years agoHi,
May I know which device you are programming? Have you tried on other system?
OHarb1
6 years agoThis is an Arria 10 device.
We've set up an automated test-server (to test incoming pull request) and we're seeing this failure occasionally on that server.
That this is not stable is problematic as it reduces the throughput of that test-server.
