OHarb1
6 years agoCrash in quartus_pgm
We're doing regression testing on a build server and we need to program the FPGA using quartus_pgm.
However, we find that quartus_pgm is flaky.
Is there a chance that the Quartus developers cou...
JohnT_Altera
6 years agoHi,
Usually when you do not have the blaster connected then it will show error message that there is no blaster connected. It will be helpful if you are able to provide the guide to duplicate it. The reason is that I am not able to observed the internal error you mention
- OHarb16 years ago
I know that, ideally, you'd want a reproduction procedure.
However, the stack trace should give the developers plenty of clues to hunt down the problem by code-inspection, which is why they made the stack trace in the first place.
