OHarb1
6 years agoCrash in quartus_pgm
We're doing regression testing on a build server and we need to program the FPGA using quartus_pgm.
However, we find that quartus_pgm is flaky.
Is there a chance that the Quartus developers cou...
JohnT_Altera
6 years agoHi,
May I know how can you duplicate the issue? Could you provide the full message log?
Are you able to duplicate the issue on other system?
- OHarb16 years ago
You already have the stack trace, you should be able to inspect the source code to find the missing error check/message.
Try running nios2-configure-sof with the cable detached, see if that reproduces the problem.
