12 years ago
Convolutional Interleaver: strange behaviour, any advice?
Hi, I'm developing a communication system emulator for educational purpose (university project). Now I'm blocked with the Interleaver and Deinterleaver modules I have written using Verilog. I implemented a convolutional block interleaving scheme with 8bit symbol length and 32 branches. The RTL description is composed by a bank of shift registers, a mux and a counter to control the enable bus and mux. Simulating the design (Interleaver followed by the Deinterleaver) I get a strange behaviour: data are roughly recovered but the 8th bit of every symbol is always zero and the 7th is not correct. I thought it was something related with the counter synchronization, but it seems not. Any idea? I post the code here, maybe it can be also helpful for someone else.
    /*Interleaver followed by Deinterleaver*/
    module test_interleaver(
    input  data_in,
    input valid_in,res,clk,
    output reg  deinterleaver_out,
    output de_valid_out,
    output reg counter //for debug purpose
    integer i;
    reg  clk_en;
    wire valid_out;
    reg  data_out;
    assign valid_out=valid_in;
    /*Interleaver branches*/
    reg D1;
    reg D2 ;
    reg D3 ;
    reg D4 ;
    reg D5 ;
    reg D6 ;
    reg D7 ;
    reg D8 ;
    reg D9 ;
    reg D10;
    reg D11;
    reg D12;
    reg D13;
    reg D14;
    reg D15;
    reg D16;
    reg D17;
    reg D18;
    reg D19;
    reg D20;
    reg D21;
    reg D22;
    reg D23;
    reg D24;
    reg D25;
    reg D26;
    reg D27;
    reg D28;
    reg D29;
    reg D30;
    reg D31;
    reg D32;
    wire  branch_in ;
    reg  branch_out;
    assign branch_in = data_in;
    /*counter*/
    always@(posedge clk or posedge res)
    begin
        if(res)counter<=5'd0;
        else//clk
            begin
                if(valid_in)counter<=counter+5'd1;
                else counter<=counter; //hold
            end
    end
    /*switch and enable control (these 2 modules are tested and work properly)*/
    mux_8x32 switch_int(.counter(counter),.branch_out(branch_out), .data_out(data_out));
    enable_coder en_bus_int(.counter(counter), .clk_en(clk_en));
    /*branch output assignation*/
    always@(posedge clk)
        begin
            if(valid_in)
                begin
                branch_out<=D1;
                branch_out<=D2;
                branch_out<=D3;
                branch_out<=D4;
                branch_out<=D5;
                branch_out<=D6;
                branch_out<=D7;
                branch_out<=D8;
                branch_out<=D9;
                branch_out<=D10;
                branch_out<=D11;
                branch_out<=D12;
                branch_out<=D13;
                branch_out<=D14;
                branch_out<=D15;
                branch_out<=D16;
                branch_out<=D17;
                branch_out<=D18;
                branch_out<=D19;
                branch_out<=D20;
                branch_out<=D21;
                branch_out<=D22;
                branch_out<=D23;
                branch_out<=D24;
                branch_out<=D25;
                branch_out<=D26;
                branch_out<=D27;
                branch_out<=D28;
                branch_out<=D29;
                branch_out<=D30;
                branch_out<=D31;
                branch_out<=D32;
                end
            else for(i=1;i<33;i=i+1)branch_out<=branch_out;
        end
    /*shift registers*/
    begin
            if(valid_in)
                begin
                 case(clk_en)
                32'd1:begin D1<=branch_in;end
                32'd2:begin D2<=branch_in;D2<=D2;end
                32'd4:begin D3<=branch_in;D3<=D3;D3<=D3;end
                32'd8:begin D4<=branch_in;for(i=1;i<4;i=i+1)D4<=D4;end //D1<=D0,D2<=D1,D3<=D2
                32'd16:begin D5<=branch_in;for(i=1;i<5;i=i+1)D5<=D5;end
                32'd32:begin D6<=branch_in;for(i=1;i<6;i=i+1)D6<=D6;end
                32'd64:begin D7<=branch_in;for(i=1;i<7;i=i+1)D7<=D7;end
                32'd128:begin D8<=branch_in;for(i=1;i<8;i=i+1)D8<=D8;end
                32'd256:begin D9<=branch_in;for(i=1;i<9;i=i+1)D9<=D9;end
                32'd512:begin D10<=branch_in;for(i=1;i<10;i=i+1)D10<=D10;end
                32'd1024:begin D11<=branch_in;for(i=1;i<11;i=i+1)D11<=D11;end
                32'd2048:begin D12<=branch_in;for(i=1;i<12;i=i+1)D12<=D12;end
                32'd4096:begin D13<=branch_in;for(i=1;i<13;i=i+1)D13<=D13;end
                32'd8192:begin D14<=branch_in;for(i=1;i<14;i=i+1)D14<=D14;end
                32'd16384:begin D15<=branch_in;for(i=1;i<15;i=i+1)D15<=D15;end
                32'd32768:begin D16<=branch_in;for(i=1;i<16;i=i+1)D16<=D16;end
                32'd65536:begin D17<=branch_in;for(i=1;i<17;i=i+1)D17<=D17;end
                32'd131072:begin D18<=branch_in;for(i=1;i<18;i=i+1)D18<=D18;end
                32'd262144:begin D19<=branch_in;for(i=1;i<19;i=i+1)D19<=D19;end
                32'd524288:begin D20<=branch_in;for(i=1;i<20;i=i+1)D20<=D20;end
                32'd1048576:begin D21<=branch_in;for(i=1;i<21;i=i+1)D21<=D21;end
                32'd2097152:begin D22<=branch_in;for(i=1;i<22;i=i+1)D22<=D22;end
                32'd4194304:begin D23<=branch_in;for(i=1;i<23;i=i+1)D23<=D23;end
                32'd8388608:begin D24<=branch_in;for(i=1;i<24;i=i+1)D24<=D24;end
                32'd16777216:begin D25<=branch_in;for(i=1;i<25;i=i+1)D25<=D25;end
                32'd33554432:begin D26<=branch_in;for(i=1;i<26;i=i+1)D26<=D26;end
                32'd67108864:begin D27<=branch_in;for(i=1;i<27;i=i+1)D27<=D27;end
                32'd134217728:begin D28<=branch_in;for(i=1;i<28;i=i+1)D28<=D28;end
                32'd268435456:begin D29<=branch_in;for(i=1;i<29;i=i+1)D29<=D29;end
                32'd536870912:begin D30<=branch_in;for(i=1;i<30;i=i+1)D30<=D30;end
                32'd1073741824:begin D31<=branch_in;for(i=1;i<31;i=i+1)D31<=D31;end
                32'd2147483648:begin D32<=branch_in;for(i=1;i<32;i=i+1)D32<=D32;end
                default:D1<=branch_in;
                endcase
            end
    end
    continued here:
    /*DEINTERLEAVER*/
    wire  data_in_de;
    wire de_valid_in;
    assign data_in_de=data_out;
    assign de_valid_in=valid_out;
    assign de_valid_out=de_valid_in;
    reg  counter_reg, counter_reg1;
    reg  clk_en_de;
    /*Deinterleaver branches*/
    reg DFF1;
    reg DFF2 ;
    reg DFF3 ;
    reg DFF4 ;
    reg DFF5 ;
    reg DFF6 ;
    reg DFF7 ;
    reg DFF8 ;
    reg DFF9 ;
    reg DFF10;
    reg DFF11;
    reg DFF12;
    reg DFF13;
    reg DFF14;
    reg DFF15;
    reg DFF16;
    reg DFF17;
    reg DFF18;
    reg DFF19;
    reg DFF20;
    reg DFF21;
    reg DFF22;
    reg DFF23;
    reg DFF24;
    reg DFF25;
    reg DFF26;
    reg DFF27;
    reg DFF28;
    reg DFF29;
    reg DFF30;
    reg DFF31;
    reg DFF32;
    wire  branch_in_de ;
    reg  branch_out_de;
    assign branch_in_de = data_in_de;
    /*counter delay to compensate data delay*/
    begin
        counter_reg1<=counter;
        counter_reg<=counter_reg1; //compensate for branch_out and data_out
    end
    /*instantiate mux and enable control*/
    mux_8x32 switch_deint(.counter(counter_reg), .branch_out(branch_out_de), .data_out(deinterleaver_out));
    enable_coder en_bus_deint(.counter(counter), .clk_en(clk_en_de));
        begin
            if(de_valid_in)
                begin
                branch_out_de<=DFF1;
                branch_out_de<=DFF2;
                branch_out_de<=DFF3;
                branch_out_de<=DFF4;
                branch_out_de<=DFF5;
                branch_out_de<=DFF6;
                branch_out_de<=DFF7;
                branch_out_de<=DFF8;
                branch_out_de<=DFF9;
                branch_out_de<=DFF10;
                branch_out_de<=DFF11;
                branch_out_de<=DFF12;
                branch_out_de<=DFF13;
                branch_out_de<=DFF14;
                branch_out_de<=DFF15;
                branch_out_de<=DFF16;
                branch_out_de<=DFF17;
                branch_out_de<=DFF18;
                branch_out_de<=DFF19;
                branch_out_de<=DFF20;
                branch_out_de<=DFF21;
                branch_out_de<=DFF22;
                branch_out_de<=DFF23;
                branch_out_de<=DFF24;
                branch_out_de<=DFF25;
                branch_out_de<=DFF26;
                branch_out_de<=DFF27;
                branch_out_de<=DFF28;
                branch_out_de<=DFF29;
                branch_out_de<=DFF30;
                branch_out_de<=DFF31;
                branch_out_de<=DFF32;
               end
               else for(i=1;i<33;i=i+1)branch_out_de<=branch_out_de; //oppure non disturbare
        end
    /* shift registers*/
        begin
            if(de_valid_in)
                begin
                 case(clk_en_de)
                32'd2147483648:begin DFF1<=branch_in_de;end
                32'd1073741824:begin DFF2<=branch_in_de;DFF2<=DFF2;end
                32'd536870912:begin DFF3<=branch_in_de;DFF3<=DFF3;DFF3<=DFF3;end
                32'd268435456:begin DFF4<=branch_in_de;for(i=1;i<4;i=i+1)DFF4<=DFF4;end //1<=0,2<=1,3<=2
                32'd134217728:begin DFF5<=branch_in_de;for(i=1;i<5;i=i+1)DFF5<=DFF5;end
                32'd67108864:begin DFF6<=branch_in_de;for(i=1;i<6;i=i+1)DFF6<=DFF6;end
                32'd33554432:begin DFF7<=branch_in_de;for(i=1;i<7;i=i+1)DFF7<=DFF7;end
                32'd16777216:begin DFF8<=branch_in_de;for(i=1;i<8;i=i+1)DFF8<=DFF8;end
                32'd8388608:begin DFF9<=branch_in_de;for(i=1;i<9;i=i+1)DFF9<=DFF9;end
                32'd4194304:begin DFF10<=branch_in_de;for(i=1;i<10;i=i+1)DFF10<=DFF10;end
                32'd2097152:begin DFF11<=branch_in_de;for(i=1;i<11;i=i+1)DFF11<=DFF11;end
                32'd1048576:begin DFF12<=branch_in_de;for(i=1;i<12;i=i+1)DFF12<=DFF12;end
                32'd524288:begin DFF13<=branch_in_de;for(i=1;i<13;i=i+1)DFF13<=DFF13;end
                32'd262144:begin DFF14<=branch_in_de;for(i=1;i<14;i=i+1)DFF14<=DFF14;end
                32'd131072:begin DFF15<=branch_in_de;for(i=1;i<15;i=i+1)DFF15<=DFF15;end
                32'd65536:begin DFF16<=branch_in_de;for(i=1;i<16;i=i+1)DFF16<=DFF16;end
                32'd32768:begin DFF17<=branch_in_de;for(i=1;i<17;i=i+1)DFF17<=DFF17;end
                32'd16384:begin DFF18<=branch_in_de;for(i=1;i<18;i=i+1)DFF18<=DFF18;end
                32'd8192:begin DFF19<=branch_in_de;for(i=1;i<19;i=i+1)DFF19<=DFF19;end
                32'd4096:begin DFF20<=branch_in_de;for(i=1;i<20;i=i+1)DFF20<=DFF20;end
                32'd2048:begin DFF21<=branch_in_de;for(i=1;i<21;i=i+1)DFF21<=DFF21;end
                32'd1024:begin DFF22<=branch_in_de;for(i=1;i<22;i=i+1)DFF22<=DFF22;end
                32'd512:begin DFF23<=branch_in_de;for(i=1;i<23;i=i+1)DFF23<=DFF23;end
                32'd256:begin DFF24<=branch_in_de;for(i=1;i<24;i=i+1)DFF24<=DFF24;end
                32'd128:begin DFF25<=branch_in_de;for(i=1;i<25;i=i+1)DFF25<=DFF25;end
                32'd64:begin DFF26<=branch_in_de;for(i=1;i<26;i=i+1)DFF26<=DFF26;end
                32'd32:begin DFF27<=branch_in_de;for(i=1;i<27;i=i+1)DFF27<=DFF27;end
                32'd16:begin DFF28<=branch_in_de;for(i=1;i<28;i=i+1)DFF28<=DFF28;end
                32'd8:begin DFF29<=branch_in_de;for(i=1;i<29;i=i+1)DFF29<=DFF29;end
                32'd4:begin DFF30<=branch_in_de;for(i=1;i<30;i=i+1)DFF30<=DFF30;end
                32'd2:begin DFF31<=branch_in_de;for(i=1;i<31;i=i+1)DFF31<=DFF31;end
                32'd1:begin DFF32<=branch_in_de;for(i=1;i<32;i=i+1)DFF32<=DFF32;end
                default: DFF1<=branch_in_de;
                endcase
                end
        end
    endmodule
