Converting a Evaluation License from Fixed to Float
- 2 years ago
Hello! I was able to solve it myself, the issue was as simple as Quartus not being in $PATH. Which was given away because I wasn't able to invoke the quartus command and had to run it directly from ./opt/intel/intelFPGA_pro/quartus/bin/quartus. I am not sure why that leads to the issue with the license being read incorrectly however.
export $PATH=$PATH:/opt/intel/intelFPGA_pro/quartus/bin/ does the trick.
We are glad that you have found the solution for this issue and hope all is well. With your confirmation, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
