Convert Programming File to Internal Configuration via quartus_cpf.exe?
Dears,
is there a procedure to generate files for "Internal Configuration (Max10)" using quartus_cpf.exe (or from another command line application)?
Now, I must:
1) generate manual on "Converting Programming Files window" (see atached file..)
2) run bat file, where: convert * .rpt to * .hex and run uploader.exe
Step 1) is "too long" and must be docummented. Generating via quartus_cpf.exe could be moved to a bat file 2) and be easy for another developpers.
Thank you, Tomas
- sstrell
This article talks about adding quartus_cpf to a Tcl script to run during compilation:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd10312014_481.html
Does that help? There may be other options available for scripting. Run "<install dir>\quartus\bin64\quartus_sh --qhelp" from the Run window or command line to see the built-in scripting help for all Quartus executables and equivalent Tcl commands.
#iwork4intel
- TKapi
Great, that's easy and it works. Thank You!
Tomas
- ShafiqY_Intel
Hi TKapi,
To convert multiple sof files into a .pof:
- use a Conversion Setup File (.cof) created with the Convert Programming Files dialog box in the GUI
And run command below:
quartus_cpf -c <input_cof_file>
i.e. quartus_cpf -c output_file.cof
To convert single a .sof into a .pof:
run command below:
quartus_cpf -c <input_sof_file> <output file pof>
i.e quartus_cpf -c blinkLED.sof output.pof
