TKapi
6 years agoConvert Programming File to Internal Configuration via quartus_cpf.exe?
Dears, is there a procedure to generate files for "Internal Configuration (Max10)" using quartus_cpf.exe (or from another command line application)? Now, I must: 1) generate manual on "Converting ...
sstrell
6 years agoThis article talks about adding quartus_cpf to a Tcl script to run during compilation:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd10312014_481.html
Does that help? There may be other options available for scripting. Run "<install dir>\quartus\bin64\quartus_sh --qhelp" from the Run window or command line to see the built-in scripting help for all Quartus executables and equivalent Tcl commands.
#iwork4intel
