TKapi
6 years agoConvert Programming File to Internal Configuration via quartus_cpf.exe?
Dears, is there a procedure to generate files for "Internal Configuration (Max10)" using quartus_cpf.exe (or from another command line application)? Now, I must: 1) generate manual on "Converting ...
ShafiqY_Intel
6 years agoHi TKapi,
To convert multiple sof files into a .pof:
- use a Conversion Setup File (.cof) created with the Convert Programming Files dialog box in the GUI
And run command below:
quartus_cpf -c <input_cof_file>
i.e. quartus_cpf -c output_file.cof
To convert single a .sof into a .pof:
run command below:
quartus_cpf -c <input_sof_file> <output file pof>
i.e quartus_cpf -c blinkLED.sof output.pof
