BBBBo15
2 years agoControl SRAM On DE2-115
Hi, I am trying to read and write a buffer on an FPGA, and I want to use SRAM to read and write this buffer. However, I have tried two different methods, but I still couldn't get the SRAM to correctl...
AdzimZM_Altera
2 years agoHello,
May I know which design that you're used to do the testing?
- Is it you own design or Intel design example?
Do you check if the design is passing timing analysis?
Is the pin location has been assigned correctly based on the board?
Adzim
BBBBo15
2 years agoHi Adzim,
It's my own design.
It says "Quartus Prime Timing Analyzer was successful. 0 errors, 24 warnings".
In compilation report, Timing Analyzer/ Unconstrained Paths/Summary, and ../Clock Status Summary is in red color.
sorry if i misunderstood it and Time Analyzer, i haven't use Time Analyzer yet.
yes, all pins are assigned correctly in Pin Planner
Thank you.
