12 years ago
Control shift registers with FPGA
Hi all, I am new here. I tell you my problem. I have been now several days trying to figure it out how to control shift registers SIPO 74LS164 with my FPGA. I am doing a clock, displaying hours, minutes and seconds with NIXIE tubes. What I need to do is to send each second, 24 bits, and remain those 24 bits displaying in the NIXIE tubes during the second, till the new second comes and new 24 bits are sent. Maybe this is a stupid question but I don't know how to produce my clock signal and my serial output to control this ICs.I already have a vector of 24 bits and the schematic of how cascading these ICs so that's not the problem. I think you get which my problem is.Please if somebody can help me would be so so great!Thank you very muchRegards
    Finally! It worked! I didn't use the "hold" state at the end, I didn't see it neccesary and it seems to work fine, I'll continue checking it to see if its consistent in time. However I paste here the code again, in case someone has the same problem or see something wrong in it.
    I don't know how to thank you for your help, you saved me. I wish one day I can return the favor. Thank you very much!
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_1164.ALL;
    USE IEEE.NUMERIC_STD.ALL;
    entity control_unit2 IS
      port (reset: in std_logic;
            clk: in std_logic;
    		trigger: in std_logic;
    		data : in std_logic_vector (23 downto 0);
            data_out : out std_logic;
            clk_out : out std_logic);
         end control_unit2;
    Architecture Behavioral of control_unit2 is
       type state_type is (start, load, pulse, rst, shift, check);
       signal pstate, nstate : state_type;
       signal data_reg : std_logic_vector (23 downto 0);
       signal data_next: std_logic_vector (23 downto 0);
       signal i_reg : unsigned (4 downto 0);
       signal i_next: unsigned (4 downto 0);
       signal datout_reg, datout_next: std_logic ;
       signal clkout_reg, clkout_next: std_logic;
         BEGIN
         clocked: PROCESS (clk,reset)
         BEGIN
    	if (reset = '1') then
           pstate <= start;
           i_reg <= (others => '0');
           data_reg <= (others => '0');
           datout_reg <= '0';
           clkout_reg <= '0';
           elsif clk'event and clk = '1' then
    		pstate <= nstate;
    		i_reg <= i_next;
    		data_reg <= data_next;
    		datout_reg <= datout_next;
    		clkout_reg <= clkout_next;
    		end if;
    	end process clocked;
         states: process(datout_reg, pstate,data,trigger,data_reg,clkout_reg,i_reg)
         begin
    		data_next <= data_reg;
    		i_next <= i_reg;
    		clkout_next <= clkout_reg;
    		datout_next <= datout_reg;
    		case pstate is
    			when start =>
    				if trigger = '1' then
    					i_next <= to_unsigned(24,5);
    					data_next <= data;
    					nstate <= load;
    					clkout_next <= '0';
    				else
    					nstate <= start;
    				end if;
    			when load =>
    				datout_next <= data_reg(23);
    				nstate <= pulse;
    				clkout_next <= '0';
    				i_next <= i_reg;
    			when pulse =>
    				data_next <= data_reg(22 downto 0) & '0';
    				clkout_next <= '1';
    				nstate <= rst;
    				i_next <= i_reg;
    			when rst =>
    				i_next <= i_reg;
    				clkout_next <= '0';
    				nstate <= shift;
    			when shift =>
    				i_next <= i_reg - 1;
    				nstate <= check;
    			when check =>
    				if i_reg = 0 then
    					nstate <= start;
    				else
    					nstate <= load;
    				end if;
    			end case;
    	end process states;
    	clk_out <= clkout_reg;
    	data_out <= datout_reg;
        END Behavioral;
    Pdta: I will read one of those books! Thanks!
