12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- @kaz Yes I can see the sum building up soon and avg taking values. One observation during hardware testing is when I increase the number of samples from 128 to 256, I receive the ADC current values slowly. The less the number of samples, the faster I get the averaged values on GUI. But the values I receive is always like 4mA, 8mA, 15mA, 25mA....., 100mA, 101mA, 102mA, 100mA, 99mA... I want to recieve only in the small range of 10mA eg.. between 95mA and 105mA. Is there a way that I can discard values such as 4mA, 8mA,.....90mA and recieve the value when it comes in range between 95mA and 105mA. How can I use signaltap in my code? --- Quote End --- For the issue of not receiving initial build up values until it settles, yes you can do that readily: with avg and avg_final starting at zero(at reset) if avg > 95 then avg_final <= avg; -- update end if; signaltap does not require code change but is a tool that you need to learn and capture data from any node for display or saving into files. It is added to project through the quartus before compilation. I assume your adc signal is a constant value but remember that adc signal may start with +/- values due to noise or step response and thus may average slowly up
