12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- This device has figures for Fsclk & Fs separately. I understand that min Fs is 50Ksps and max Fs is 200Ksps. The Fsclk has then to be fast enough for 12 bits (in fact 16 times as Fs) i.e. Fsclk(min) = .8MHz and 3.2MHz(max). Yet you are using Fsclk of 15KHz i.e. Fs = 15KHz/16 = .9KHz appart from violating device spec. Am I right? --- Quote End --- The FSclk is 312KHz which means Fs= 312/16=19.5 KHz
