12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago@kaz
'done' is coming from the SPI master block indicating valid transfer. Yes I am sampling each adc sample through it. Also as I told you before there are two outputs of ADC. i-e 'adc_a_out' and 'adc_b_out' 12 bit each. In the end I do the 'and' of both of these outputs and I have 24 bit value of ADC and then send to GUI via USB interface.
