12 years agocontinuous averaging using VHDL
I have a question related to VHDL programming. I want to calculate the continuous average. My example code is:
process (clk, reset)
begin
if (reset = '1') then
state<=idle;
out-v...
12 years ago --- Quote Start --- What else should I do in order to achieve for example 100mA instead of 4 mA, 8 mA, 15 mA,.......100mA. I need stable value directly. What else can I do in the code? --- Quote End --- your running average should work. Are you sampling eacg adc sample through it. What is that done = '1' for and do you stay in state out_1 enough to do the job. Your adc data rate of 15KHz should be averaged sooner unless it starts low.
